PowerBook G3 VCore Adjustment (?)
Astal
57
21
An Alternate Timeline
Hello! I have my G3 wallstreet and I'm trying to figure out where to adjust the vCore! I heard it might be on the CPU card, I can't find any documentation beyond "I'm adjusting the vCore" on what the hell it actually is and any insight would be welcome.
1,351
I too have a Wallstreet but never tried to overclock it, so I cannot provide help about voltage adjustments. But you only need to adjust voltages when overclocking, and how are you going about that?
Astal
57
21
I've been in contact with DosDude and Bolle, they helped figure it out, there's a resistor divider, I installed an IBM PPC750S on the card is why, and it wants a much lower vCore than the Motorola XPC750.
Astal
57
21
We figured it out.
R49 and R48 are in parallel and then R47 is in series with it. This makes up R2 on the formula for the vCore...
vCore = 1.23 * (1 + 10k/R2)
These here
1,351
So basically you swapped the CPU on your card in the PowerBook Wallstreet, not because the CPU was bad, but because you were hoping for better performance, even at the same clock speed, but you found that you needed to adjust the voltage going to the new CPU in order for it to become stable, correct?
Astal
57
21
I had a CPU sitting here and it was the first thing I saw to glue it on to :p
And I am wondering why Wallstreet and not Pismo or Lombard? :)
Because I own a Wallstreet already
Reactions: JDW and retr01
