I've been working on a Quadra 660AV that had heavy capacitor damage. (good reset and clocks on main chips, no chime, seems like CPU locks after a few cycles)
In the process, I've been documenting stuff like voltages, signal descriptions, and resistance to ground for a good board. All my info is on this spreadsheet in case anyone is in a similar situation (there will be updates as I continue work).
docs.google.com
I also have some info about what happens if you remove various chips from the board:
all onboard RAM- chimes normally (no death chime!), but no video. can add SIMM to boot normally
U51 / DSP- will chime and boot fine (possible hang if SIMM installed)
U52 / NEWAGE (floppy controller)- will chime and show gray screen, but no cursor or flashing floppy
U20 / CURIO- will chime and show mouse but waits indefinitely (mouse works)(Y4 does not work without curio)
U55 / MEMCTL- no act (TEA high, BERR float/low)
660AV documentation
