If you're looking to recap the PSU from your Quadra 700 and/or you have a Mac with an Astec AA15831, here's the complete list of all the electrolytic and film safety caps.
For convenience, here's a DigiKey list of everything you need: https://www.digikey.com/en/mylists/list/X1H5MFVEFT
Note that some of the parts listed below are no longer being manufactured, so you'll need to come up with appropriate replacements. For example, C25 calls for a 180uF part, but that's a value that's largely become obsolete, so you'll want to pick a 220uF part instead. The same goes for some of the film safety caps.
Main PSU board:
PSU daughterboard:
PSU AC input board:
Main PSU board:
| Location(s) | Capacitance | Voltage | Diameter/length | Height/width | Lead spacing |
| C7, C8 | 470uF | 200V | 22mm | 40mm | 10mm |
| C6, C35 | 3300pF | 250V Y film safety | 13mm long | 4mm wide, 9mm high | 10mm |
| C28 | 1000uF | 16V | 10mm | 28mm | 5mm |
| C20 | 2200uF | 16V | 12.5mm | 28mm | 5mm |
| C22, C23 | 1500uF | 10V | 10mm | 28mm | 5mm |
| C27 | 470uF | 16V | 8mm | 19mm | 5mm |
| C25 | 180uF | 16V | 6mm | 15mm | 5mm |
| C30 | 4.7uF | 50V | 4mm | 8mm | 2.5mm |
| C31 | 100uF | 35V | 8mm | 12mm | 5mm |
PSU daughterboard:
| C214 | 2.2uF | 50V | 5mm | 11mm | 2.5mm |
| C217 | 4.7uF | 50V | 4mm | 8mm | 2.5mm |
PSU AC input board:
| C4, C5 | 4700pF | 250V Y film safety | 13mm long | 5mm wide, 10mm high | 10mm |
| C10 | 4.7uF | 400V | 10mm | 20mm | 5mm |
| C11 | 100uF | 35V | 8mm | 12mm | 2.5mm |
| AC inlet board | 1000pF | 250V Y film safety | 13mm long | 4mm wide, 9mm high | 10mm |
