Following in the footsteps of @Elemenoh, I have disassembled a monochrome/greyscale Radius Pivot (model 0361 - apparently identical to models 0276 and 0425) in order to recap it. Deflection and geometry are perfectly stable, but the image itself is trash. The symptoms are almost identical to the ones experienced by my Apple Portrait Display from a few years ago when I acquired it from a warehouse in Houston. Its geometry was far less stable, though.
This, too, being a warehouse find, decades of exposure to uncontrolled heat/cold and humidity have almost certainly trashed the caps here as well (as was the case for the APD). The weather down here in the DFW area is supposed to be absolutely miserable this weekend (hello, freezing rain!), so I'm hoping to pick up a will call order form Mouser before then and will hopefully have a nice little recapping project in a few days... if the power stays on through the inch or so of freezing rain we're supposed to get.
I hope to make photos/video available as well, but the disassembly process is a real pain. If you need to work on one of these, I'd just say to shotgun all the caps in one go, lol.
Anyway, without further ado (dimensions are approximate):
| Board | Part No. | Capacitance | Voltage | Diameter | Height |
| Main Deflection Board | C109 | 47uF | 35V | 8mm | 11mm |
| Main Deflection Board | C118 | 100uF | 35V | 8mm | 11mm |
| Main Deflection Board | C126 | 100uF | 200V | 18mm | 40mm |
| Main Deflection Board | C127 | 22uF | 100V | 8mm | 11mm |
| Main Deflection Board | C129 | 100uF | 16V | 8mm | 11mm |
| Main Deflection Board | C137 | 47uF | 35V | 8mm | 11mm |
| Main Deflection Board | C140 | 100uF | 25V | 6mm | 11mm |
| Main Deflection Board | C142 | 1uF | 250V | 8mm | 11mm |
| Main Deflection Board | C143 | 4.7uF | 50V | 6mm | 11mm |
| Main Deflection Board | C145 | 1uF | 250V | 8mm | 11mm |
| Main Deflection Board | C148 | 220uF | 25V | 8mm | 11mm |
| Main Deflection Board | C306 | 47uF | 35V | 8mm | 11mm |
| Main Deflection Board | C313 | 100uF | 100V | 12mm | 20mm |
| Main Deflection Board | C314 | 1000uF | 25V | 16mm | 20mm |
| Main Deflection Board | C318 | 47uF | 50V | 6mm | 11mm |
| Main Deflection Board | C326 - Bipolar | 22uF | 35V | 8mm | 11mm |
| Main Deflection Board | C327 | 100uF | 25V | 6mm | 11mm |
| Main Deflection Board | CX114 | 1000uF | 16V | 12mm | 25mm |
| Main Deflection Board | CX307 | 220uF | 35V | 8mm | 11mm |
| Main Deflection Board | CX309 | 100uF | 35V | 8mm | 11mm |
| Main Deflection Board | CX315 | 4.7uF | 35V | 6mm | 11mm |
| Neck Board | C403 | 22uF | 16V | 5mm | 11mm |
| Neck Board | C413 | 1uF | 100V | 5mm | 11mm |
| Neck Board | C414 | 100uF | 10V | 6mm | 11mm |
| Neck Board | C416 | 100uF | 10V | 6mm | 11mm |
| Neck Board | C418 | 22uF | 16V | 5mm | 11mm |
| Neck Board | C424 | 100uF | 10V | 6mm | 11mm |
| Neck Board | C427 | 100uF | 10V | 6mm | 11mm |
| Neck Board | C451 | 100uF | 10V | 6mm | 11mm |
| Neck Board | C452 | 47uF | 10V | 5mm | 11mm |
| Power Supply | C529 | 2200uF | 35V | 18mm | 36mm |
| Power Supply | C5?? | 220uF | 450WV | 30mm | 45mm |
| Power Supply | C513 | 470uF | 25V | 10mm | 20mm |
| Power Supply | C514 | 470uF | 16V | 8mm | 11mm |
| Power Supply | C516 | 470uF | 16V | 8mm | 11mm |
| Power Supply | C527 | 47uF | 200V | 18mm | 40mm |
| Power Supply | C528 | 150uF | 200V | 18mm | 36mm |
| Power Supply | C531 | 220uF | 25V | 8mm | 11mm |
| Power Supply | C532 | 1000uF | 35V | 18mm | 20mm |
| Power Supply | CX517 | 1uF | 50V | 5mm | 11mm |
