The DefaultDesktop I have is the photo of a sand dune that comes up when I'm logging in after a restart. Good to know I can change that! But not what I'm looking for. And sadly the search for 'Linen' didn't turn up anything either. Good suggestion, though!Try looking for /System/Library/CoreServices/DefaultDesktop
Or use a utility like EasyFind to search for file name "linen"
Try mounting the Recovery partition (since that's where you saw it) and look in the same places suggested, but on that partition.The DefaultDesktop I have is the photo of a sand dune that comes up when I'm logging in after a restart. Good to know I can change that! But not what I'm looking for. And sadly the search for 'Linen' didn't turn up anything either. Good suggestion, though!
Yeah, so what I ended up trying was relaunching Recovery Mode, and using Disk Utility to save an image of the partition and saved that to my hard drive. Then I poked around all through there but still couldn't find it. The interface in Recovery Mode suggests there might be an app somewhere titled OSX Utilities, and this image might be part of that bundle, but still can't find that on the image.Try mounting the Recovery partition (since that's where you saw it) and look in the same places suggested, but on that partition.
How do manually mount hard drive on mac?
My mac recently gave up and I'm trying to salvage whatever data I can from the hard drive. I was able to boot using the OSX Installation CD and fire up Disk Utility that basically told me that the ...superuser.com
I'm not sure which OS you're using, but if it's an oldie, you can also try this method to mount the Recovery partition on older OS versions:
How to View & Mount Hidden Partitions in Mac OS X with Debug Menu in Disk Utility
By enabling a hidden debug feature in Disk Utility, you are able to both view and mount hidden partitions on hard drives in Mac OS X. Hidden partitions include things like Linux swap, GUID partitio…osxdaily.com
Alternatively, if you have a disk image of the OS Installer, you can maybe use EasyFind to locate it on that mounted image by searching for "linen" including package contents and invisible files.
