Restoring my SE to SE/30 conversion with a noisy fan
reallyrandy
81
New Jersey
I'm restoring my SE/30 that was an SE conversion and the fan is super noisy. I pulled a quiet fan out of an SE parts machine but I discovered that the noisy fan has wires and the other one has 2 terminals sticking out the back. It looks like the analog board has a place to solder in a fan with terminals though. Could it be as simple as just soldering in the new fan and leaving the original wires clipped?
The two fans
The original wires for the wired fan
The unused terminal ports on the analog board
MacOfAllTrades
168
182
This sounds awesome — I don’t know the answer to your questions. But if you’re confident the replacement fan is of similar power requirements then why not just touch the existing yellow/black wires from the board onto the connectors of the replacement fan and see what happens?
