SE/30 AB making a clicking sound
Cam
22
10
OK. So I've been following the rebuild of Branchus Creations on YouTube, as Bruce repaired a battery bomb SE/30 and decided to give repairing mine a go.
The damage to my board was confined to the space around the battery was once upon a time, and I think I've managed to fix all tha PCB traces that were borked. I plugged the LB into a working AB (an SE that I have), flipped the switch and get a a very faint ticking sound coming from the AB board.
My question: Is this sound an indication of a short on the SE/30 LB? If I put the SE LB back in place everything is fine, so it has to be something bad on the board I'm repairing. I'm sure the ticking sound is a clue, I'm just not sure what it's a clue to . . .
Any help is much appreciated.
C
Nixontheknight
206
38
C
that's an indication that the power supply is being short-circuited, so I'd say check the board for shorts and try recapping it
Cam
22
10
So given that the AB powers the vanilla SE LB, that means the short has to be on the SE/30 board (since connecting it causes the clicks).
Guess I'm going to have to tone out the voltage rails, looking for continuity to the ground plane (?).
Thanks,
C
Cam
22
10
Took a while, but found the short (pins 63/64 of the ROM SIMM) once fixed, the ticking stopped.
Now on to the next issue; the video output . . .
C
Reactions: fred1212
