SE/30 with Serial Port Issues - Fails Snooper "Handshake Test"
Garrett
141
South Carolina
Hi all, I am working on an SE/30 that works with the exception of the serial ports. Snooper 2 is my go-to for testing, as it seems to be reliable in picking up problems.
The issue is, the entire system crashes when I run the serial port tests. With loopbacks connected, it'll give me the "handshake test - OK" and then lock up. With no loopbacks connected, I get the "handshake test - BAD" message followed by a freeze. This seems to indicate that there is some functionality here, just not 100%.
I have recapped the board and checked traces between the serial ports, the serial controller itself, and everything in between. I did have one intermittent connection between UC12 and UG12, so I removed UC12 for cleaning and then replaced it.
This didn't solve the issue, so I went ahead and removed the UG12 chip hoping to find bad corrosion under it. Nothing found though - it looks really really nice and clean. Argh! How often do these chips fail? I have repaired many of these boards and have never had Snooper actually lock up. Most of the time it'll just fail and move onto the next test if there's a problem.
Any thoughts or ideas? Going to swap in another UG12 I had saved for a reloaded board, but I'm really doubting that's the problem.
1,962
Are there any pull up/down resistors on the serial ports lines? maybe something to check (spitballing)
Garrett
141
South Carolina
Only thing I can see in schematics are the Bournes RP2 and RP3, which I checked out as part of my initial probing. Other resistors include R40-R43, but I'd doubt that's the cause because they're going to the edge connector on the front of the board. Thanks for the idea though, keep them coming!
Garrett
141
South Carolina
All fixed!
A replacement SCC did the trick. I actually used the chip I had saved for my sleek black reloaded board, but seeing Snooper run without issue was worth the sacrifice. That new board is socketed, so I'll give the old chip a test at some point.
If the old controller chip was bad, it was only partially bad, because System 7 would still startup with it. Without the chip installed, it would hang up at boot. Either way I'm happy to have another working SE/30!
Reactions: eric
