JDW's good instructions YouTube video:
Production environment
-Since the VRAM chip is a recycled product, the height of the foot varies slightly, so all are hand-soldered without using reflow.
-A craftsman who has used a soldering iron for 30 years has worked for all products.
- We will ship products that have passed the test with LC475 overclocked to 50Mhz. * Depending on the usage environment, we may not be able to promise 50MHz. Especially, recap using OS-CON is necessary.
-It is finished by ultrasonic cleaning using IPA cleaning and PMA cleaner.
Specifications
- 2pcs per set
- VRAM capacity: 512KB (1024KB for 2pcs)
- Speed: 60Ns
- Guaranteed CPU overclock: 49Mhz*
- Theoretically, the CPU overclock limit is 55Mhz with SMC-VRAM, but the actual limit varies by machine specifications. High CPU clock speeds are also contingent on the use of extremely low ESR capacitors on the motherboard. Before shipping, we will test VRAM at 50Mhz.
- Appearance: Blue LEDs are installed.
Compatible Macs
LC475, LC575 (Mystic), Quadra650 (AKA Centris650), Quadra 800 / 840AV
Shopping here:
SMC-VRAM 512KB 60Ns for 68040 Overclocking/ 2-PCS per set | infinityproducts
Satanic Mac Club has engineered an entirely new VRAM SIMM for vintage Macs. This new, low latency 60ns design allows you to take CPU overclocking to an all new level!*The design base is from alxlab (Alexandre Marcoux). Sold with permission.https://github.com/alxlab-zone66x Specifications • 2pcs...
en.infinityproducts.co.jp
