[SOLVED] Simasimac almost(?) fixed
naruse
Hey Everyone,
I am working on fixing a mac SE/30 board I got and I have been following these steps:
(1) Check and clean connections between SIMMs (ROM-SIMM) and SIMM (ROM-SIMM) slots, and restart.
// Checked and moved the rom, and sometimes it works sometimes it doesnt mostly it doesnt
(2) Remove PDS card(s) such as an accelerator card if installed, and restart.
// I dont have PDS card so all good
(3) Check the battery. Replace it with a new one if voltage is low, and restart.
// Replaced it with a cr2032 new one
(4) Replace electrolytic capacitors C6 (1µF 50V) and C7 (47µF 16V) on the logic board with new ones.
 // I replaced them all with tantalums 20v (and the axial ones as well)
(5) If solution (4) doesn't work, pull up the sound IC chip (UB11). You can see letters "SONY 0F09G 3430045B APPLE85" or "SONY 9A04 3430045B APPLE85" printed on the chip. To pull up the IC chip, connect pin 7 to pin 15 of the chip with a 1 kilo ohm resistor.
//Well... I did this and it actually improved the stability of the system!
So I am down to solution #5 which is bypassing that IC by literally soldering a 1k ohm resistor between lets 7 and 15 and everytime now that I start the machine it beeps :).
But Sometimes the system shows the horizontal strips and (still beeps) and moves to the floppy question mark state, but yet sometimes it freezes :( (but still beeps!.
I always move a bit the rom (I have the original rom) and sometimes just works the next time I switch juggle it a bit.
My question to the hyvemind:
How can I know for 100% sure that the issue is the Sound chip? -- and if its the sound chip (UB11); how come that when I bypass it it still beeps? 🤔 (I know there are 2 though).
Also, was the old rom as finicky as the new ones? (i.e rominator) that one has to keep moving it to make better compacts?; or could this mean that I should replace the socket? (I have ordered some deoxit D5 to apply to it and see if the behavior improves)
I will try to make a video to show what is happening if I can later on.
naruse
Scratch what I said; I can reliably reproduce simasimac (and fix it) by soldering / taking out the 1k ohm resistor between legs 7 and 15 from UB11 :D
