Sound Blaster 16 drivers/settings for Windows 3.1
Stinkerton18
105
85
Hey folks!! Have you ever tried to run or install the Sound Blaster 16 Non-Plug-and-Pray drivers using something more modern, storage-wise? It's...it's a chore. The installer likes to just hard lock when you get to the install phase and it does a disk space check. Well, I got tired of this, setup the most minimal DOS 6.2.2/Windows 3.1 on a just 500MB drive to get the files/settings needed.
So here we are. The attached zip has the following:
  • C:\SB16 folder with drivers and software
  • AUTOEXEC.BAT file with just the Creative changes
  • SYSTEM.INI with just the drivers/Sound Blaster settings for Windows 3.1
  • The DRV files to put in C:\Windows\System
The AUTOEXEC.BAT and SYSTEM.INI files in the attached zip contain only the Creative/SoundBlaster stuff, making (hopefully) super easy to copy/merge into your existing files. Install should be as easy as:
  1. Place the SB16 folder in C:\, so you have C:\SB16
  2. Copy the DRV files to your Windows\System folder (usually C:\Windows\System)
  3. Copy the contents of this AUTOEXEC.BAT to your C:\AUTOEXEC.BAT file
  4. Copy the contents of this SYSTEM.INI to your Windows\SYSTEM.INI file (usually C:\Windows\SYSTEM.INI)
  5. Reboot
Hope this helps others!
  • SB16.zip
