Successful compact flash upgrade for PowerBook 3400c
christcc2
View attachment successful-compact-flash-upgrade-for-powerbook-3400c-v0-1bfrp9jsd8jf1.webp
I recently picked up this 3400c that for the most part is in excellent condition other than needing a new power adapter, a replacement PRAM battery and maybe some service to the power supply board. (Or a replacement one).
After reading through Jeff Geerling’s restoration post and some posts on 68kmla I decided on an IDE to compact flash adapter and a SanDisk 4GB card.
Both worked immediately and were recognized by HD Setup. I split the card into two partitions - one for System 7.6.1 and the other for more data.
This 3400c came with a 32MB RAM upgrade. I’m going to pickup a larger RAM card in the future.
- https://www.amazon.com/dp/B00S6GIHS2
- https://www.amazon.com/dp/B0007QU6ZQ
Credit to Jeff Geerling and his blog posts and video that helped guide me along.
What isn't shown here is that the power supply board has been finicky - the PRAM battery was leaking and I cleaned that up. I didn't see any bad traces, but corrosion had moved through the battery wiring harness. I soaked that board in alcohol for a day and cleaned it. The caps aren't leaking - but I'm going to recap that board as a next step. I replaced the PRAM battery and relocated it to another part of the enclosure.
It's starting to come together. Great companion to my PowerBook 165c which was my first PowerBook restoration.
Reactions: eric and phunguss
