Swapping components SE & SE/30
iantm
16
6
Michigan
Obviously the one thing that can’t be swapped is the logic board.
But I’m under the impression that I can pull an analog board and some other components from one the donor SEs I have.
What else can you salvage and pull from an SE into an SE/30? Any caveats about the idea?
Mk.558
84
25
The difference is the logic board, some slight differences in the chassis, the front case part, swapping the floppy drive to a 1.44MB drive if it was originally a SE with 1 or 2 800K drives. The back case is functionally identical, just a different label on it. The analog board, PSU, CRT and CRT neck board are the same. I don't know about the Classic or Classic II, but the 128K through SE/30 all use the same CRT.
