I have two Greaseweazles, a v4.0 and v1 (the one based on an STM32 "Blue Pill") Both have been working flawless for a while now except for recently. The one I used internally in my main Linux system (USB 2.0 header to port, short micro cable, PCB in a printed enclosure) has recently run into a very, very strange issue. No matter what floppy drive (I've tried 3 different, tested good ones) I use, ALL attempts to write an image result in the same failure: Command Failed: GetFluxStatus: Flux Underflow
Here's what I've done:
Has anyone else run into this? Any ideas at this point? Why would literally every other operation work except writing from an image file?
- Used both the V4 and V1 in this system
- Tried each with all 3 known-good PC drives (can take these drives plug them into two different 486 boards, a Pentium/Socket 7 motherboard, A Pentium SBC, Pentium 3 Copper Mine, and Pentium 4 SBC, all read/write/boot, with no issues)
- Tried reflashing the latest firmware on both Greaseweazles
- Deleted/downloaded/installed the gw tool again
- Ran with sudo
- Cleaned the drives with a cleaning disk (even after they worked in the systems above)
- Read 1.44MB/720K floppies to an image
- Perform a cleaning operation to "zig-zag" the heads
- Perform an RPM test
- Erase a disk fully
