What printers are you using?
jojo2k
24
17
As the title says. What printers are you running? You have them networked, or connected directly to certain computers? What kind of print server if any?
For everyone courageous enough to use and work on vintage printers… you deserve an award. But darn if they aren’t fun when they do work.
684
HP ENVY Photo 7858 - This is my current network printer. It usually is in my wife’s office as NP until I finish refurbing my 8625 which won’t happen until my office is redone.
HP OFFICEJET pro 8625 - my everyday network printer but is currently out of service needing deep head cleaning and tlc.
Epson 740i in Grape - this is connected locally to a matching Grape imacg3 :)
HP DESKJET 820Cse (for Windows) - currently on a shelf until I refurb/refill its carts and give it some tlc. I picked this up for free off CL because it still has its marketing stickers and I want to run it locally between a couple era correct win boxes I have with a Belkin compact parallel Autoswitch F1U115E (not currently set up). It is the big brother to my first color printer my parents got me when I was starting highschool in the 90s so it brings back the feels when I look at it :)
The thing is all of this stuff is offline while I finish giving my office a repaint and new wood floor lol. I hope to finish it this week at which point I have to decide if I want to go with my old layout or try something new. Either way I need to also install a power plug, pass through box and wall mount for my old heavy flatscreen because it’s I/o is what I need for all my retro consoles etc … so all that to say all these setups I’m referencing are packed away taking up 3/4 of my entertainment/tv room while I get this done lol.
Oh yeah I also have a dot matrix mps-802 for my C64. It lives in my closet lol and I don’t think Ive touched it since 2000 maybe so once the dust settles and hopefully life slows down a tiny bit maybe this winter, I can break it out and give her some tlc and a new ribbon and see if she’ll still print with quick brown fox.
iantm
154
66
Great Lakes
I've got a Phaser 6280, which I have yet to get working with my classic Macs. Allegedly possible through the LaserWriter 8 driver. I'll either get ethernet working or find a bridge to LocalTalk.
Then there's the opposite end of the spectrum, an ImageWriter II. I don't get tired of the sound and lo-fi output of that tank.
billgoats
I have an ImageWriter II with AppleTalk card, which is always a delight! With both black, and colour ribbons.
Then there's the StyleWriter 2400, with the Farallon box to get it on the network too. The colour printouts are surprisingly good. The paper feed tries to grab all the sheets every once in a while, but it's mostly.
And recently got an Apple Scribe thermal printer. It's been a bit finicky to work out, but did manage to get it working with an old Mac using regular serial cable and the regular ImageWriter driver. For some reason it needed dip switch 8 down, but the manual says up. It works perfectly without a ribbon on thermal paper.
thecloud
58
59
Like @billgoats , I have an ImageWriter II, but it doesn't have an AppleTalk card. It's connected via serial cable to a networked Mac running Simple Spooler, which lets other machines on the network see and print to it. The whole old-school dot matrix printer experience sparks joy for me again.
Also have a Brother HL-5170DN with AppleTalk capability, so of course it's registered on the network as "What's Happening Brother".
2,274
Same ImageWriter II with an AppleTalk card for vintage comptuers
For modern I have a networked Brother InkJet/scanner/etc that seems to work just fine for color.
Got a free HP LaserJet Pro that we use for B&W - wifi as well.
And a Q5 label printer for shipping things - had to modify it a bit to make it work on Linux since it's a cheap no-name branded label printer https://github.com/erichelgeson/nixos-tspl-label-printer
And I have my ImageWriter I we used on our mac plus - but it is very heavy and rusty I think - that one's just for show heh.
fred1212
146
Brother MFC-J5320DW and Brother HL-L3230CDW Network mounted via netatalk on Debian 13.
Various Stylwriters
KennyPowers
354
384
I have an Apple Dot Matrix Printer (A2M0058) and ImageWriter II that I occasionally hook up to various Apple II and Mac systems. Then I have a Panasonic dot matrix printer that I've connected to some of my Osbornes. Finally, I have a NeXT Laser Printer (N2000) that I fully restored and is currently connected to my NeXTCube.
tom_B
53
53
Connecticut
2d:
I have a m402dne that I rescued from the ewaste pile at work that I use. Has some sort of roller issue or something that leaves faint lines on the edge of the printer but works fine for few the things I print on letter. Networked. If I need something in better quality I'll just print it at work, but that's a very very rare occasion
I have a "Omezizy D520BT" label printer I use for 4x6 shipping labels, USB to my main PC. It's been rock solid for a few years
Apple ImageWriter II with a LocalTalk card, usually only in use for Globaltalk during Marchintosh. Hooked up via phonenet and I also have a bridge that I use to connect it to AppleTalk ethernet devices(Asante Ethertalk or something like that)
3d:
Bambu P1s with AMS
splorp
178
Calgary, Alberta
splorp.com
Our main printer since 2016 is a Xerox WorkCentre 6027 multifunction unit. It’s connected via ethernet to a gigabit switch off our cable modem router. I’m in the process of finally setting up a Localtalk to Ethernet bridge so my vintage machines aren’t stuck with the StyleWriter.
Scott
58
29
Right now we are exclusively using ImageWriter IIs with the older Macs. I have one at home and two for the lab. All of these are equipped with the AppleTalk card.
I have another one in the lab storage unit that doesn't work with the network despite a known good card inside (tested on another printer). I know that one has some issues with caps though.
I have a StyleWriter that won't work with any ink cartridge and a LaserWriter II that needs caps.
For modern printing, I have an HP Color LaserJet M254. There's also an OfficeJet 100 around for mobile printing and a LaserJet 1022 in storage. Somewhere I also still have my Epson Stylus 740 (just the beige version since it was cheaper back in 2000) and an HP DeskJet 722C.
