Store
12V Power Conditioning Board board for RPi and LCD Controller: need help on this one . . .
Looks like PowerBook 100 batteries are only 6V, so I guess the new build batteries from @360alaska are out of the picture. :confused...
Mar 18, 2025
PowerBook 100/RPi-CM4-Lite
Well that didn't take a lot of research! Looks like I should be able to desolder the "internal" HDMI connector and replace it with the...
Mar 18, 2025
Quadra 630 Boards and Misc
A Contemporary 21" CRT sitting center stage beside a 5x00 would make a very nice setup. ;)
Mar 18, 2025
1152x870 is the best I ran across. However, with 1.5 MB of VRAM, I would think it could do more at 8-bit color.
Mar 18, 2025
alxlab
Performa/LC 630 Dos Compatible - Dos Card CPU Upgrade
You'll need an 486/5x86 interposer to covert the SPU voltage from 5V to the 3V of a Intel 486 DX4 and set the proper multiplier...
Mar 18, 2025
SE/30 with jail bars
Yeah, my chip didn't look too bad but when I removed it, the legs fell off at the base, making me think the corrosion was worse inside...
Mar 17, 2025
caver01
Connecting eMate to Mac OSX - "there was no response"
Today, I tried connecting my old PB5300cs. This is booting into OS8 off of a PC card Compact Flash adapter. No internal HDD. I also...
Mar 17, 2025
Settling into waiting (impatiently) for components to arrive mode again. After all these years in process I should really be more...
Mar 17, 2025
This my first time a firmware hacking, and I starting with a working firmware update procedure. Without the stock firmware update step...
Mar 17, 2025
D
domb84
Great work on the firmware adjustments. I have an m127 machine which appears to be much the same as the kodak etc but runs different...
Mar 17, 2025
