Store
Floppy drive Sony MP-F51W-23 upper head doesn't touch the disk
Incorrect. Pin-1 is marked on the PCB and on the chip itself with a dot, and it should follow this diagram: You also need to verify...
Mar 19, 2025
B
billbucks
Thanks for your feedback. The suggestion I got won't work so I'll look for a SWIM replacement unless I figure out how to wire some UJ11...
Mar 19, 2025
The difference between a "SWIM" and "IWM" is very important for the SE/30. As I said in my previous post, you need a SWIM, not an IWM...
Mar 19, 2025
B
billbucks
My intent is to remove the error screen and not use the floppy drive on the Mac SE30. If I use the IWM, could it solve this issue i.e...
Mar 19, 2025
You would need the newer SWIM chip, not IWM, because you are using an SE/30. @Kai Robinson created a PLCC-to-DIP adapter in the past...
Mar 19, 2025
B
billbucks
Someone suggested I could reuse the IWM chip from a Mac SE board (see photo) which I have. Could it work ? The corresponding pins could...
Mar 19, 2025
W
wskjinfen
Macintosh Plus 4Mb Weak Sound on Startup and Slugish Beahaviour
Test the PAL chip by swapping it with a working board.
Mar 19, 2025
Version 5.8 Attached. This version correctly sets the full range flag within the `avcC` MP4 atom. So not a big change, but will save...
Mar 19, 2025
svenvendetta
iMac G4 Dies
PowerMac G4, iMac G4 & eMac
So I got an iMac G4 a few years back, cleaned it all up, maxed it out, and got ATA to SATA installed. All worked great. Used is a total...
Mar 19, 2025
Two SE/30 Boards - memory woes
I had an SE/30 board which had been through some repairs in the past, but which still had unexplainable intermittent issues that did not...
Mar 19, 2025
