Store
SCREWS for SE & SE/30 Analog Board to Metal Chassis
Don't force fit a mismatch like that. For the bolts, go with drilling and tapping for a standard thread transplant. For the black sheet...
May 23, 2025
68k
Determining amount of installed RAM
If you want to be compatible with Apple's Switcher, don't forget to check it's low memory global before calling MFTopMem. Otherwise...
May 23, 2025
ryandesign
68k
Oh! You know, I've been spending too much time with Retro68, where you don't get much glue. I remembered that other environments have...
May 23, 2025
craig.sacco
Building my own 68k Performa / LC / Color Classic Test Bench
HI mate, I was wondering how far you got to for resolving your sound issue. I have a similar issue with a 580CD with an irreparable...
May 23, 2025
B
billbucks
Floppy drive Sony MP-F51W-23 upper head doesn't touch the disk
Thank you for your feedback. I indeed need to check that. The initial fix was suggested by ChatGPT... (I don't always trust it but it...
May 23, 2025
Your pin numbering is correct for UJ11. But you are saying that UJ11 pins 20, 21 and 38 need to be pulled-up to 5v via 10kΩ resistor...
May 23, 2025
B
billbucks
Hi, I'm going to make an attempt to fix the board without floppy drive support. Attached is an updated view of UJ11 connector's pins...
May 23, 2025
Does that mean you've never purchased the screws used to affix the SE Analog Board to the metal chassis? No doubt there must be at...
May 23, 2025
P
Paolo B
It’s an interesting one, my experience is that sourcing exact spares for our beloved vintage stuff may turn really difficult. Generally...
May 23, 2025
68k
Looks good. BTW: Gestalt in often implemented in compiler glue to provide basic services when the OS doesn't actually have Gestalt. Not...
May 23, 2025
