Store
Eric's ANS 700 tinker log
So I took up the challenge to port Doom to Harpoon AIX. After some feverish late night hacking on Doom Generic and a sprinkling of...
May 27, 2025
Marconelly
"475 Overclock" control strip on Color Classic Mystic - problems and solutions
Would it be possible to use a thermal tape with the large copper heatsink? I'm not so much interested in maximum performance, but would...
May 27, 2025
neonfire
Restoring a relatively decent iMac G4
I should have another card in another machine, but I'll have to check. Good call on the pins, I'll check those, and I didn't know the...
May 27, 2025
It is not impossible to bend the pins in the socket. Remove the card and have a look to see if any pins are bent. It could be a faulty...
May 27, 2025
neonfire
I reseated the card already, and I think 10.4 is installed, but I'll have to double check. I looked in Apple Profiler but under airport...
May 27, 2025
Check the wifi card to see if one is actually installed (or reseat it if one is installed). The OS should see it automatically. What...
May 27, 2025
neonfire
PowerMac G4, iMac G4 & eMac
Got an iMac G4 finally recently after always wanting one as a kid. It works well, but it doesn't see the Airport card at all. I'm not...
May 27, 2025
robin-fo
ZiLOG discontinues the Z80 & Support IC's in June 2024
Looks like Mouser will stock the Z85C30 again in 2026..?!
May 27, 2025
Floppy drive Sony MP-F51W-23 upper head doesn't touch the disk
Again, I am no expert on these SWIM chips, nor do I have experience toying with them as you are. But any signal-level pins like RESET...
May 27, 2025
B
billbucks
Thank you for the link, it is very interesting. I looked at pins linked with the CPU that would be worth connecting to the GND (pin 1)...
May 27, 2025
