Store
yyzkevin.ca has been working on making BlueSCSI the first SCSI emulator to work with the odd IBM AS/400 drive standard. Here's his...
Jun 23, 2025
B
Brionco
It looks like the stock FW when sharpness is set all the way up. I was seeing these dots in highlights as well. -B
Jun 23, 2025
Marconelly
iMac G3 speaker replacement success
Looks like these speakers are no longer available on Aliexpress. @mac27 do you have any other suggestion of what to buy? Someone on...
Jun 23, 2025
Marconelly
Color Classic VGA Woes
Right now, I've adjusted the PP7 pot, and managed to get the low voltage to be 4.998 / 5.004 V and 11.8. Up from 4.8V / 11.5V - I can...
Jun 23, 2025
croissantking
reviewed the resource
PPC Macintosh L2 Cache Modules
5.00 star(s)
Helpful resource. BTW, C01 has been seen on a PowerMac 6500 board.
Jun 23, 2025
Retronaut
Help needed getting A2SCSI card visible on Apple IIgs
An update on the issue, and yes, its certainly VOODOO I found 3x .hda images on the BlueSCSI site, one is a basic install of GSOS...
Jun 23, 2025
MacEffects Appreciation Post
Yes, I've used the 8001 with the transparent oil spray finish. I've had some very good parts, and some that were not nearly as good...
Jun 23, 2025
Retronaut
Apple I/II/III
This is a re-post from Apple Fritter forums, as this is a pretty specific problem, I thought it best to spread my net wider... Hey, I...
Jun 23, 2025
nekogahora280
SE/30 with abnormal screen
I replaced two capacitors near the sound chip and one capacitor near UE8. The startup sound played, but the screen remained covered with...
Jun 23, 2025
JeffC
What was the screen displaying before the recap? Did you only replace some of the caps on the logic board?
Jun 23, 2025
nekogahora280
Compact Macs
What is the cause of this SE/30 symptom? After replacing some of the electrolytic capacitors, the startup sound came out. I think it's...
Jun 23, 2025
