Store
XKSTEVE
SOLVED Apple //e with PAL composite video displaying issue
SOLUTION Turned out this issue was caused by a faulty SN74LS374N at location UF7 (international board) UD3 (NTSC boards). All traces...
Jun 25, 2025
speakers
PowerMac 7100 and Linux
I've tracked down the ram mis-configuration issue to a problem with BootX's PDM video re-mapping. BootX modifies the memory map passed...
Jun 25, 2025
Marconelly
Color Classic VGA Woes
That's where it is, yes. I have found that it leads to J23 jumper lead on the upper side, and measured between there and the metal cage...
Jun 25, 2025
S
Sjuul010
Can se/30 flyback be replaced by a 157-026C flyback?
Compact Macs
I bought a 157-026C flyback, not realizing it is meant for a Macintosh Plus, and thus is an older type than the one that is used in the...
Jun 25, 2025
Retronaut
Help needed getting A2SCSI card visible on Apple IIgs
Anyone? no response, in the meantime, I have made some progress with this on other forums. At least in terms of what the issue might...
Jun 25, 2025
This Does Not Compute
MacEffects Appreciation Post
I'm in for a clear resin brightness knob as well!
Jun 25, 2025
Mac84
Yes, but keep in mind the live preview of the image before you record is different from the results of the recording. With the live...
Jun 25, 2025
Markintosh
2009 iMac slot load CD into a Cube
Oh-that is Fantastic! I DO have a 3D printer as well-Thank you!
Jun 25, 2025
Markintosh
Jun 25, 2025
Yes. You may have to make some adapters to align the mount holes. I have mounted a SATA slot load thin drive from an aluminum iMac...
Jun 25, 2025
Markintosh
PowerMac G4, iMac G4 & eMac
Hey Gang! is it possible to install an ‘09 iMac Slot load drive into a G4 Cube??
Jun 25, 2025
