Store
Retronaut
Apple IIe Card: Add Hard Disks, Making Floppy Disks and Much More!
Video is live NOW!
Jun 30, 2025
Here is Kodak Vision 3 negative (home developed) through my modified Reels scanner. Not too bad. The white balance was changed to...
Jun 30, 2025
S. Pupp
Help with CRT image on Macintosh Classic I
You have a screen geometry problem, and need to adjust the small black square magnets around the yoke. It is a pain to do because of...
Jun 30, 2025
Radius Full Page Display for Macintosh 512ke/Plus - Cloning project possibilities?
Very strange, that looks like the Killy Klip setup. If so it would clip onto the 68000 on the mobo? There were ceramic and plastic...
Jun 30, 2025
Retronaut
Apple I/II/III
Apple IIe Card: Add Hard Disks, Making Floppy Disks and Much More! The Apple IIe card, the last great hoorah for Steve Wozniaks and...
Jun 30, 2025
PowerMac 7100 and Linux
You can but there's also a checksum to update. It's a simple algorithm so you could just make a perl or python or bash script. You can...
Jun 30, 2025
S
SchoolBusII
Macintosh Classic II -12 Voltage Issue
Thank you - replacing IP3 fixed the issue.
Jun 30, 2025
S
SchoolBusII
LCD Screen Inside Compact Mac Case
Thank you!
Jun 30, 2025
madcow
Not the best images, but what I could snag tonight quickly. I don't have the cable to connect to it, but I do have the display and it...
Jun 30, 2025
P
pff000
I used a 'sandwich' of several pieces to mount the Pimoroni screen, in the following order, all held in place by the regular CRT screws...
Jun 30, 2025
jmacz
SE/30 RTC issues
An SE/30 with SCC chip issues or problems on the serial circuit will fail to boot under System 7.x whereas it works fine under System 6...
Jun 30, 2025
