Store
This is what I have in my JLC3DP Cart right now... 1) Resin Printing (no brim needed): Resin is more brittle and less forgiving when it...
Jul 12, 2025
Retronaut
LCII - static display issue
Check also if the caps themselves for the video area are intact, could be a damaged trace in that area, as it has been re-capped, it...
Jul 12, 2025
slomacuser
Fonts Before Mac (1983)
I will write about it later. There were hundreds of twiggy discs imaged for museum in California and some leaked out.. after 10 years...
Jul 12, 2025
nekogahora280
Macintosh IIfx 68030/50Mhz???
I remember that I removed the crystal a few times but It didn't start. That's the only way to get the original crystal It was plugged in...
Jul 12, 2025
Hugotronics
Did you make sure the crystal was oriented correctly? It worked fine for me twice.
Jul 12, 2025
Scott
Major Personal LaserWriter NTR Woes!!
Having some major Personal LaserWriter NTR woes here!! First, the paper almost ALWAYS jams. I've tried thicker paper (i.e. resume...
Jul 12, 2025
caver01
What's Stopping Me From Getting An M4 iPad Pro? OLED Issues
Hmmm. I own the 13 inch M4 Pro and have not had any issues. I do almost all of my daily computing on it and spend many hours every night...
Jul 12, 2025
PowerMac 7100 and Linux (and NetBSD)
I did mention that in #7 You can set output to ttyb:57600 to increase the baud rate. A small patch is required to enable...
Jul 12, 2025
decryption
That last image - BootScreen - is so cool. Matches up with some of the graphics from that time pre-1984 promoting the Macintosh...
Jul 12, 2025
caver01
I am familiar with clear TPU. I had Wermy’s MintyPi hand-held arcade system (made to fit in an Altoids tin—it was pretty nifty) that you...
Jul 12, 2025
