Store
caver01
Attached:
Jul 14, 2025
caver01
Ok, just to confirm: We are going to expand the inner diameter to 6.2 and nudge the flat out .05. I think I can do that. . .
Jul 14, 2025
So, I just tried to measure my resin print with my cheap calipers and the round hole seems to be pretty much spot on at 6.0mm. Which...
Jul 14, 2025
caver01
Would 1mm be sufficient?
Jul 14, 2025
caver01
Wondering if maybe the flat is fine since it is not given any more room with flexing from the slits. Of course, expanding the ID...
Jul 14, 2025
caver01
Of course. . . Any suggestions on how much more room you might need? The original round hole is exactly 6.00mm. The flat encroaches...
Jul 14, 2025
I measured and the only difference in depth between the resin part and the original was that the original has a deeper hole in the...
Jul 14, 2025
PowerMac 7100 and Linux (and NetBSD)
Appears to be C strings followed by variable type and bit number or offset (01=boolean, with bit number, 02=number with offset to value...
Jul 14, 2025
caver01
eMac swivel Base
I am finally getting this accessory finished and revisiting this post to provide the final details. First, the three socket-head screws...
Jul 14, 2025
caver01
@wottle I think they look fantastic regardless—like they are made of solid ice!
Jul 14, 2025
caver01
That’s interesting about the tightness after re-assembly. Here‘s that same ORIGINAL model installed on the board for which it was made...
Jul 14, 2025
