Store
robin-fo
Networking with a PM6500/300 and a Mac SE/30
How are you intending to do File Sharing? Using AppleTalk or TCP/IP? I‘d strongly discourage you from using TCP/IP when using LocalTalk...
Aug 4, 2025
G
GerrySch
Here's an update... I found along with the AsanteTalk network bridge some Apple three-pin cabling along with about 5 nodes to connect...
Aug 4, 2025
Umba67
Thank you 0dan0, I have quite a confusion in my head, but I'm enthusiastic! :) I'm waiting for the 12mm lens + rings to arrive, then...
Aug 4, 2025
This is not how resolution works. The sensor has maximum of resolution of 2304x1296 (Datasheet -...
Aug 4, 2025
Umba67
I have some feedback: 1. to install the 0dan0 6.6 firmware I have to use an 8gb memory card formatted FAT32. The 128 Gb card won't be...
Aug 4, 2025
Total Systems Gemini II Accelerator for the SE
Your CPU score of 8.69 in Speedometer is really good. I made these benchmarks of the MacEffects Performer, 33MHz FPU XTAL at left...
Aug 4, 2025
Umba67
Hello Deano, you are right. I didn't explain myself well, sorry. I meant that after flashing the firmware, the sensor with mac84...
Aug 4, 2025
Eric's Apple Network Server 700 tinker log
That would do it. But it's interesting you made an AIX boot floppy that way. I'm interested to see what actually got on the floppy disk...
Aug 4, 2025
:forehead slap: Well. turns out if you have a floppy disk in while installing something is written to that disk and then the startup is...
Aug 4, 2025
Deano
Your side by sides are amazing to see! How were you able to get 3280x2464 output with the 0dan0 Firmware 6.6? All I'm able to achieve is...
Aug 4, 2025
