Store
I
indibil
G4 Cube revival help?
As a curiosity, if you try to turn on the Cube with the top plate unscrewed, where the button is, since it's not grounded to the...
Aug 6, 2025
kallisti5
Macintosh Classic Floppy Drives - auto-inject.
Ha! I think I actually just fixed it. Did a little more bending of the heads with the drive out of the Classic and finally got the...
Aug 6, 2025
I
indibil
Project Satanicube (or, Xodium's G4 Cube Build)
Very good contribution. I also had a processor height issue because it was too low, and I solved it by sandwiching a thin 0.5mm copper...
Aug 6, 2025
I
indibil
G4 Cube VRM
Hi, I initially wanted to do it with a preheater and a hot air soldering iron, but I didn't want to overheat the components I'd be...
Aug 6, 2025
V
vtgearhead
Earlier this week I did the same thing to one of my SuperDrive mechanisms. After a bit of shameful language, I realized the little coil...
Aug 6, 2025
O
omega
CDenhart Thank you for trying to help me. I've tried the firmware from the link before. Some didn't work and left only red spots on the...
Aug 6, 2025
kallisti5
Compact Macs
I just finished restoring my Macintosh Classic (new caps, retrobrite case). It's working perfectly minus one thing... the floppy drive...
Aug 6, 2025
DIY Desktop Video Microscope #2 for Micro Soldering
Here is a Penny and circuit board to compare. Penny close up Circuit board wide and close up I think that is pretty good for $6.
Aug 6, 2025
jasperman
G4 Cube VRM
Thanks indibit! Do you have a surface mount soldering set up with a hot plate? Or did you manage to make these modifications with just a...
Aug 6, 2025
