Store
B
blturner
Recapped Mac II with NUBUS issue
Congrats on your success @DevyDevly! I was working on my board last night, I ended up replacing every 74ALS651 with chips from a Mac II...
Aug 12, 2025
DevyDevly
Sooo… turns out I had a broken trace (DSACK0 - data strobe acknowlege) from the NuChip (22) to the GLU (59). These data strobe signals...
Aug 12, 2025
OneGeekArmy
Disk Jockey v4 for macOS is out
My goal is to try and support older Macs as long as possible (which I think makes sense for an application aimed at retro enthusiasts)...
Aug 12, 2025
JustG
Thank you for continuing to build this for older OS versions! I like to compartmentalize my interests between modern computers and the...
Aug 12, 2025
jdmcs
How to: Build an External Power Supply for Atari 520ST (Using Parts from Amazon US)
DOS Fox told me that the Cisco 34-0874-01 power brick is another candidate for making an Atari 520ST power supply. Might be good to keep...
Aug 12, 2025
V
vtgearhead
Macintosh Classic Floppy Drives - auto-inject.
I find it's much simpler and safer to remove the entire "top" (load) assembly before accessing the heads. There's a great video on...
Aug 12, 2025
V
vtgearhead
SE/30 Recap Gone Wrong
Did you recap the analog board as well? If so you may have inadvertently broken the vertical circuitry. In particular, examine the...
Aug 12, 2025
