Store
O
omega
Can anyone tell me how to remove the lens cap? I thought it was snapped on, but I can't. I would like to check if the focus is OK.
Aug 15, 2025
yomatiase
Emate 300 without battery pack
I got a better image...
Aug 15, 2025
jdmcs
LC II vs. 4MB SIMM Problem
The LC II is compatible with standard 30-pin SIMMs that are rated 100ns or faster (-10 or smaller for the timing). The LC II doesn’t do...
Aug 15, 2025
Reverse PAL / GAL Truth Tables
Sorry about the noob inquiries, but would appreciate a little input here, need a starting point for learning a bit about this stuff. ;)
Aug 15, 2025
Elemenoh
No but you should be able to work backwards by measuring the hole the 'pin' goes through and the enclosure parts where it rests. Good luck!
Aug 15, 2025
yomatiase
Ohhh.. do you have a better photo of that piece, maybe I could replicate it.
Aug 15, 2025
Elemenoh
You're missing the plunger that pushes in the switch
Aug 15, 2025
Mac84
Thanks for the revised 3D model. Can you please share it by attaching it to a post here? I'd like to see if it solves the issue I have...
Aug 15, 2025
yomatiase
I think I have a new version of this. I have like this square thing and this switch on the board...
Aug 15, 2025
V
vtgearhead
Recapped Mac II with NUBUS issue
You may have a fractured or digested pin on one of the ICs.
Aug 15, 2025
