Store
jdmcs
LC II vs. 4MB SIMM Problem
I’ve been told that the 10MB limit is in the ASIC itself, which would mean that it would not be possible to overcome the limit with an...
Aug 16, 2025
jasperman
M1212 cut off at bottom
CRT
Hi all, The picture attached is a M1212 CRT attached to a Performa 6300 CD. I have verified the Performa will drive a VGA monitor...
Aug 16, 2025
speakers
PowerMac 7100 and Linux (and NetBSD)
Tried to fix it but quotes remain mucked up. The web editor isn't helpful :confused: >hwint3 is 211C0 but the A2 was 17135E0. Right.
Aug 16, 2025
Genjoke
Think you very much! I’ll try the memory check. I had no idea either that the motherboard memory was the one to be disabled. Btw...
Aug 16, 2025
JeffC
Corroded legs on IIsi CPU
I was able to fix my board, I'm not sure what the original problem was, probably related to the ALS245s. The final issue I was able to...
Aug 16, 2025
Umba67
I drilled the printed piece with a modeling micromotor (don't know if the translation is correct) by eye, trying it in place until the...
Aug 16, 2025
Umba67
Ok, I dismantled It. :) Since the back of the camera has a square shape, you have to remove a block of plastic that expose the hole...
Aug 16, 2025
Mac84
I misunderstood. I guess I was confused that there was an image of a 3D model… and assumed it could be downloaded
Aug 16, 2025
fishgee
My reading (perhaps incorrectly) of his modifications are that he drilled/filed/shaped the original model. He said the STL needed to be...
Aug 16, 2025
Umba67
I'm not very good with the dynamics of these posts, I answered in the other thread you posted. Sorry
Aug 16, 2025
Mac84
You posted a photo of the 3D model you modified to fit the camera mount. Can you please upload the 3D model printable file (STL, Step...
Aug 16, 2025
