Store
Apple Aluminum foot / skid - 3D printed STL files
3D Printing
I have both a 20 and 23 inch Aluminum displays with missing foot pad / skit / rubber piece. Model A1081 and A1082. They seem to be...
Aug 24, 2025
fishgee
The cover is held in place by 6 tabs that click into slots in the face of the scanner. To get it off from the front, push up on the...
Aug 24, 2025
Steve Rieck
Can new PLCC chips be programmed for the SE/30 ?
Thanks so much for your expertise Kai. Will go through those next. I really appreciate the help!
Aug 24, 2025
If CPU wasn't working you wouldn't be getting a chime, likewise with the GLU - honestly i think it's either RAM MUX/resistor packs...
Aug 24, 2025
Steve Rieck
Thanks. Will check oscillator and clock...Do you think I can make any conclusion about the GLU and CPU other than they are somewhat...
Aug 24, 2025
ph4z
A Tale of Three SE/30s - Restoration and Upgrade Log
Log entry #3: After watching just about every YouTube classic mac repair video, I finally felt confident to repair my three SEs. I also...
Aug 24, 2025
D
displaced
iMac G3 service and rebuild (with MacEffects inner bezel)
Seems the tint problem isn't uncommon. For example, https://discussions.apple.com/thread/8000298?sortBy=rank -- which looks identical...
Aug 24, 2025
I'd imagine the ROM is fine, given the death chime. When my Iifx went wonky, turned out to be poor oscillator connection and clock signal.
Aug 24, 2025
Manifested worries about the Y2K38 and Y2K40
David, thanks for the detailed explanation! We know that if you pull the PRAM battery, not only will the Date/Time be wrong, but your...
Aug 24, 2025
G
GerrySch
Keychain and OS 9.1
Software | Mac OS (PowerPC)
I'll make this short - I have a PM6500 running 9.1, fresh install from CD. I also have an LC475 and SE/30 on the same home network...
Aug 24, 2025
