Store
T
Towmater
Photogrammetry : ok for organics, bad for mechanics
Spray it with foot powder talc, then “flick” cinnamon onto it to create the stochastic noise texture that photogrammetry requires. Tough...
Aug 26, 2025
Steve Rieck
SE/30 Reloaded Board - First Test
Yes, I'm referring to chips I removed from a stock battery bombed SE/30 board. They had little corrosion being so far from the battery...
Aug 26, 2025
robin-fo
Wait — With „harvested“, @Kai Robinson probably means bought used/second hand from unknown origin. You probably will have no issues at...
Aug 26, 2025
Steve Rieck
Would this work? I'm getting no PLCC results for "65C22N" on mouser or digikey. Thanks for your help...
Aug 26, 2025
chuck.dubuque
Analog board - display horizontal alignment
This has to be adjusted from the centering rings on the yoke board. Caution: hazardous high voltage issues here, so take care and do not...
Aug 26, 2025
Steve Rieck
very interesting. Thanks for the heads up! Will do.
Aug 26, 2025
Ah, this might be the issue. @techknight and @This Does Not Compute had an issue with a reloaded board using harvested VIA's - they're...
Aug 26, 2025
Steve Rieck
Harvested. i'd like to find new ones but I'm not sure how.
Aug 26, 2025
Are the via chips new, or harvested?
Aug 26, 2025
ph4z
A Tale of Three SE/30s - Restoration and Upgrade Log
Thanks! However, I already recapped and cleaned the logic boards. The issues described were cross verified on different analog boards...
Aug 26, 2025
Sideburn
ImageWriter II Pi Print Server for Modern Retro Printing
Ahh yes it is a pi 4 because it is in this case: https://a.co/d/aEA6gb6 Still working great!
Aug 26, 2025
Sideburn
Oh man I cant remember already but I'm pretty sure it is a 4.
Aug 26, 2025
Steve Rieck
Weird. When I remove just one of the VIA chips UK11 or UK12, I get a death chime at startup. That's progress maybe. New at least. When...
Aug 26, 2025
