Imac g3 refusing to do anything
Have you used the iFixIt guides for your disassembly or did you just wing it? I would disassemble and verify you have made all...
Aug 27, 2025
H
Honk-ie
Its a tray loader, pre 2000s atleast. Family number: m4984
Aug 27, 2025
S
Scout
What is is tiny ciruit board
Oh that makes sense. Thank you so much. Not sure how it attaches. did I accidentally break it off of something? I will open the...
Aug 27, 2025
There are many models of the iMac G3, so please include info from the data plate. What color? Is it tray load or slot load?
Aug 27, 2025
H
Honk-ie
The screen does not power on at all, but the cd drive will spin up and I the hard drive will spin up too. I checked before I put the...
Aug 26, 2025
Photogrammetry : ok for organics, bad for mechanics
I tried the foot powder with a puck mouse disassembled and it still came out horrible (all parts attached to a tube to get the best...
Aug 26, 2025
1. Does it power on now without the 4 beeps? Screen comes on? Do you hear the Apple chime? Yes to all, ok, no to all, recheck your...
Aug 26, 2025
Garrett
That’s your PCMCIA eject button PCB. Plugs into your logic board - easy to miss!
Aug 26, 2025
S
Scout
Compact Macs
Took apart a PowerBook 5300 and after reassembly I found this on the table. The laptop appears to be working so I have no idea if this...
Aug 26, 2025
H
Honk-ie
PowerMac G3 & iMac G3
I recently picked a imac g3 and when I originally bought it, it would beep 4 times and then do nothing. I did some research and found...
Aug 26, 2025
S
StudioLou
Easy way to transfer files to and from iMac G3?
Hi Byte Knight. I have the same problem – old files on a G3 – and ran a quick export test using your Server. It worked! I wanted to get...
Aug 26, 2025
