6.0 just has the longer exposure, which caused more jitter for me, so there some hardware dependency. I will try to make the exposure...
Aug 30, 2025
S
superjer2000
Applied Engineering TransWarp TW1340 - Information Wanted
Hi I just acquired the Mac Classic version of this accelerator (TW2340). Similar to some other posts I’ve found, I can’t get the card...
Aug 30, 2025
W
Willj
Here is the video link
Aug 30, 2025
ACGuy
[SOLVED] Macintosh SE works but has no sound
Okay, updates on this one. I desoldered the old chip, and replaced it with a socket. Like this, I made some measurements, after manually...
Aug 30, 2025
fehervaria
From MacSketch to MacPaint
The only way I can understand this, is the very early version numbers counted from the beginning of the development phases, like...
Aug 30, 2025
Umba67
Hi, I downgraded to firmware 6.0. I digitized a Kodak Vision3 200T, there is no issue with the jitter nor with the color ghosting. I...
Aug 30, 2025
W
Willj
FYI @JDW has and amazing video on the rom programmer and how to use the software along with how to make images to use. Even has loads of...
Aug 30, 2025
F
frontein1
Just to point out, you can easily change the size of the disk image on these ROMs if you do not have an 8MB SIMM. Just change the...
Aug 30, 2025
F
frontein1
Attached is ROM checksum F1 A6 F3 43. This ROM has a 7MB disk appended, so you will need an 8MB SIMM. Any of the machines listed below...
Aug 30, 2025
