John Galt
ImageWriter II Pi Print Server for Modern Retro Printing
Nope, I have exactly what you have. I just wanted to mention the fact a USA-19HS can probably be used in lieu of the USA-28X models we...
Sep 7, 2025
Color Classic Resolution Switching
Now that I've done the 84V Mod, I can answer my own question. I only did a single test with the IIe Card installed on the stock CC...
Sep 7, 2025
T
ThePhage
I really like the reduce compression feature of Topaz Video AI. Based on this, I finally have taken a look at it's trial version. I have...
Sep 7, 2025
@frontein1 I have two questions: QUESTION #1 Mustermann's thread on the MLA says he wanted to DISABLE the soldered 4MB of motherboard...
Sep 7, 2025
Software-only OVERCLOCK for LC475, LC575, Quadra 605
MYSTIC UPGRADE: Hacks/Mods Clarified Today, a viewer of my 475 Overclock video said he has an LC575 board in his Color Classic without...
Sep 7, 2025
Sideburn
Did you need the DP9 type serial because you have an ImageWriter and not an ImageWriter II? I had to use the DIN style. I am doing the...
Sep 7, 2025
F
frontein1
Taking an idea from user @Mustermann on the 68kmla, I have a new version for the LC475/Q605 which bypasses counting the onboard memory...
Sep 7, 2025
misterg33
Error 403 – unable to access Macintosh Garden anymore
@fogWraith -- Can you check to see if the garden is reachable when iCloud private relay is on?
Sep 7, 2025
Where can I find pinouts of HDI-20 and HDI-30 ports? Trying to make an adaptor so I can use my HDI-20 external floppy on the powerbook 145B
Unless I'm missing something, the HDI-30 was a SCSI connector. Not sure you could use it to connect a floppy drive. Here's the...
Sep 7, 2025
Sideburn
Pretty sweet huh? Gives a whole new life to the LaserWriter.
Sep 7, 2025
John Galt
Well, it was as simple as you described. Perhaps even simpler. As you wrote, pretty freakin' awesome! My ImageWriters are connected to...
Sep 7, 2025
