jmacz
Upgrading Powerbook 190 to 68040 with FPU?
I have successfully done it on a PowerBook 540c and a PowerBook Duo 280c. @croissantking is the first I saw do it successfully (the...
Sep 13, 2025
indigo_k
Can You Run System 7.5.3 On A G4 MDD?
Easiest way to check is to hold Option while booting. It'll find any supported System folders and give you the option to startup from them.
Sep 13, 2025
Got My Transparent Inner Bezel From MacEffects Installed
I install them exclusively in my SE and SE/30 machines, so I’m well aware of their low noise benefits. But I’ve never installed four in...
Sep 13, 2025
I recall reading somewhere about someone else doing this successfully, ...and something about only specific CPU part numbers working in...
Sep 13, 2025
IIRC @This Does Not Compute tried this with a 540c and....no luck.
Sep 13, 2025
New platinum filament...
What printer, firmware, and slicer are you using? I am using an Ender 3 Pro (with silent board), with similar settings to all other...
Sep 12, 2025
mcbeav
Does anyone have any recommendations for settings when printing with this filament? This is the first time I've used this brand, and...
Sep 12, 2025
Nixontheknight
they're Noctuas, they're quieter than the average fan
Sep 12, 2025
mcbeav
I am not using anything to reduce the RPM's. I used 4 because about a quarter of each fan is blocked just due to the amount of space...
Sep 12, 2025
