MacSE analog board issue – squished video, flyback overheating
The pdf is in the resource section.
Sep 21, 2025
Anyone refurb 400K Floppy drives?
I saw you were getting hassled in “that other forum” today. Some people are in serious need of tact. Just wanted to follow-up to see if...
Sep 21, 2025
The BU406 (Q2) mounted to the metal cage is the usual suspect. Could be CR2 as well. See pages 51-52 in the following Larry Pina book...
Sep 21, 2025
N
NJRoadfan
AppleShare over IP with my BlueSCSI v2 and classic Mac
You need to turn on one of the older UAMs in order to login. See: https://netatalk.io/manual/en/Configuration#which-uams-to-activate...
Sep 21, 2025
Ubik
My very first NeXTStation
Welcome to the dark side. It's a lot of fun to to run the NeXus :) of OS X.
Sep 21, 2025
gopherman
Manifested worries about the Y2K38 and Y2K40
A potential answer hiding in plain sight! 😂 (I haven't actually tried it either.)
Sep 20, 2025
What’s really interesting about this is that we all could simply change our date to 2040 today and see what happens. Full disclosure...
Sep 20, 2025
D
dourish
Compact Macs
I’m trying to get AppleShare over TCP running via my (external) BlueSCSI v2 from an SE/30 running 7.5.5. The BlueSCSI has firmware...
Sep 20, 2025
gopherman
Having run quite a few Macs with dead/missing PRAM batteries, the main problem that I can see is that some software refuses to run (or...
Sep 20, 2025
CamInTosh
Compact Macs
Hi everyone, lot of info I'll try to break down. This is a new acquisition I've had for about a month now. Current Problem Screen...
Sep 20, 2025
Destroyer1976
Can anyone help with installing open core to install macOS 15 sequoia
Ah ok, thanks. I'll try it again today
Sep 20, 2025
You should NOT have to if your card was bios modified to work on mac.
Sep 20, 2025
Destroyer1976
do I have to click 'AMD GOP Injection' at all?
Sep 19, 2025
