Mac84
Tecmar Mac Drive (10 MB) A serial hard drive?! (The first Macintosh external hard drive)
I only took a quick peek, but it looked like copper, similar to this "clock" someone made and posted on eBay of the same model drive. :oops:
Sep 24, 2025
Mac84
Thanks David, I'm currently performing a number of those steps today. I didn't think of testing the enclosure without the drive...
Sep 24, 2025
Check the continuity on all of the serial cable pins. The MacGUI article indicates the drive clocks the serial port externally. Use a...
Sep 24, 2025
iMac G4 Logic Board Diagnosis and Repair: Is it possible?
The DDR333 PC2700 will down clock itself and is backward compatible to PC2100. That should not be an issue. Anything loose? Can you...
Sep 24, 2025
jeffburg
The only thing I can think of is it doesn't like the ram because it's DDR333 PC2700. It's what Other World Computing sent me when I...
Sep 24, 2025
jeffburg
Yeah, I tried both slots where the other slot was left empty. I have multiple ram sticks for each slot.
Sep 24, 2025
I wonder if the platters are the rusty color or the shiny type (don't open it to find out)? When I built my first satellite solar...
Sep 24, 2025
Mac84
Out of curiosity, I opened up the Tecmar "Volume Manager" software (v6.0.3) in ResEdit and looked through the alert messages. This is...
Sep 24, 2025
There are two ram slots, an internal DIMM and an externally accessible SODIMM. You have swapped both?
Sep 24, 2025
