BlueSCSI Wi-FI DaynaPort issue
This is not a valid ini file - and yes do as @robin-fo suggests. You do not need any of that extra stuff in the ini file, it is likely...
Sep 29, 2025
@dougg3 I'm going nuts! Just fired up my old Intel mid-2015 15" MacBook Pro running MacOS High Sierra and downloaded your v2.0.1 SIMM...
Sep 29, 2025
Had no time to try and flash the v091 or v092 ROMs until this evening, but sadly, my ROMmate v2 programmer simply is refusing to do the...
Sep 29, 2025
robin-fo
Best create you config with this: https://ini.bluescsi.com/
Sep 29, 2025
robin-fo
I‘d try with everything removed from the bluescsi.ini except the wifi configuration. It looks like your „virtual hd“ configuration...
Sep 29, 2025
iQQator
I assume, the driver already installed, but nor MacTCP nor OpenConnect doesn't see network at all :( But when install driver quick...
Sep 29, 2025
V
V.Yakob
Successfully connected to Wi-Fi SSID "MyWiFi" -- Reports that BlueSCSI has connected to the "MyWiFi" network, you can see it on the...
Sep 29, 2025
rdmark
Netatalk 4.0 - Future-proofing Apple File Sharing
@Slimes Did you recall what your afp.conf looked like before? You only added "log file" and nothing else? If you comment out "log file"...
Sep 29, 2025
jmacz
Quick question about some parts and an SE/30 reloaded project
My guess is those were what remained of the fuses at F1, F2, and F3.
Sep 29, 2025
PowerBook 500 series PPC upgrades
PowerBook (68k-based)
So I bought a boxed 520c off eBay and found it had a surprise Newer Technologies NUpowr 117MHz 603e/4MB processor upgrade card. I was...
Sep 29, 2025
