DevyDevly
Macintosh II, BlueSCSI, and termination
Heh… not an answer I was expecting - Cabbage Patch dolls were in vogue around the same time I suppose. Thanks for the heads up :)
Oct 5, 2025
Can you show me how dark your images are, compared to where you would like them? The exposure is both trying to avoid constant changes...
Oct 5, 2025
TheElk
Hello 0Dan0 I'am reading this forum since September 2024. My task was to cut my Super 8 films from 1988 where my daughter was 2 1/2. She...
Oct 5, 2025
I've now confirmed there is an issue with 128GB cards not working. I expect the exFAT and larger cards are using memory I trying to use...
Oct 5, 2025
Massive (filthy) find in South Carolina
Another minor update. I moved on to assessing the Quadra / Centris 610 machines. While it looks like I had 13 of these machines, I...
Oct 5, 2025
R
rms337
Thanks 0dan0. So you are saying zooming in and then capturing is OK? This thread is getting long, so a little difficult to go back and...
Oct 5, 2025
Mk.558
Mac SE/30 networking
I mean networking can be a lot simpler than you think. In System 7, you can create an alias of the server, and add it to your Startup...
Oct 5, 2025
jmacz
I positioned the 4 holes to match the layout of the bottom holes of a standard spinning disk, which is what I believe most of the...
Oct 5, 2025
ScutBoy
With SCSI on old Macs, there are two modes. 1. What the standard says should work. 2. What actually works on your machine. The...
Oct 5, 2025
S
snuci
Tecmar Mac Drive (10 MB) A serial hard drive?! (The first Macintosh external hard drive)
Take a look at this directory: https://vintagecomputer.ca/files/Apple/Macintosh/Tecmar/ Look for "Mac Drive content". It's everything...
Oct 5, 2025
O
omega
What size card are you using and how is it formatted? My 128GB was also not working on exFat. It only started working after formatting...
Oct 5, 2025
