P
pff000
Apple II Plus replica
Apple I/II/III
Hi everyone, For a while now I have been building an Apple II plus. I never had an Apple II before ... so this has been a great...
Oct 7, 2025
indigo_k
iMac G4 constantly crashing/kernel panics
I don't have another adapter or SSD, but I guess I could put the original drive back into it. The power supply I got off eBay, it had...
Oct 7, 2025
techknight
Anyone refurb 400K Floppy drives?
I do all of those repairs too, but I only take them on with a case-by-case basis, and I only am able to do that stuff on the weekends...
Oct 7, 2025
jibsaramnim
If you are using an adapter to connect your SSD, it might also be worth trying to see if using a different adapter or SSD makes a...
Oct 7, 2025
S
Sjuul010
Can se/30 flyback be replaced by a 157-026C flyback?
I ended up never installing it. When I desoldered the original one, I found more troubles on the analog board. Instead I found another...
Oct 7, 2025
Ah... The two nuts on bottom... Well, I've done that sort of removal before, mainly because the brass rod had broken, making it easy...
Oct 7, 2025
P
Paolo B
Not too difficult, indeed. There’s a metal bracket that keeps the three pieces together. There are two small nuts. In my case, the...
Oct 7, 2025
Wow. How, specifically, did you "dismantle" the flyback, and did you shoot photos of that?
Oct 7, 2025
P
Paolo B
Personally, I had a flickering and wobbling SE/30, the image sometimes going dark altogether. I desoldered, dismantled and cleaned it...
Oct 7, 2025
indigo_k
I don't remember if I did pull the motherboard out entirely or not. I feel like I started to but it ended up being a lot more...
Oct 7, 2025
