jackmonte1987
so I got everything set up and did my first capture which went well, it was only a minute long. However my second capture also went dark...
Oct 10, 2025
Marconelly
Anyone tried installing LC575 speaker in Color Classic?
I will try,, but it’s possible that he didn’t even notice it since the connector does snap in place, just harder than it normally should...
Oct 10, 2025
Mac 128k Analog Board 820-0082-B from 1983
Yep! Just ordered the kit. Been so long since I opened it up and it looked like a part number i just assumed. Thanks!
Oct 10, 2025
geerlingguy
Reinstall Mac OS on iBook G3 clamshell with only USB port?
I *was* able to boot off the USB drive, but not with the 9.2.2 Universal installer copied to it. So I pulled out a 650 MB CD-R, used...
Oct 10, 2025
R
rms337
@0dan0 Since there have been no takers, I am trying to decide if I want to order the Arduino and break out the soldering gun this...
Oct 10, 2025
The great LCD in a Color Classic thread. Well, I wish...
@ESM-NL I do apologize, but I'm still rather confused, perhaps because I've not read all the posts pertaining to this topic (which are...
Oct 10, 2025
@Marconelly Before cutting anything, I strongly suggest you reach out to that YouTuber (video in your opening post) to tell him your...
Oct 10, 2025
Dave928
pretty sure that's the part number for the bare circuit board. you need the number on the other side of the Analog Board, forward edge...
Oct 10, 2025
ESM-NL
The 16 colors limitation is only caused by the 640x480 resolution. With the original resolution with the CRT, and a standard 256k VRAM...
Oct 10, 2025
Marconelly
I tried this just now, and it turned out more tricky than it would seem. Taking the cassis out and snapping the speaker into place went...
Oct 10, 2025
Volvo242GT
What I've received as of late...
I did do just that. Not because the power supply on any of the other units was better (in fact, one was worse - cooling fan was dead)...
Oct 10, 2025
