ESM-NL
The great LCD in a Color Classic thread. Well, I wish...
Yes, that's correct. But watch out: there are two versions replacement types ABs: one type that only works for the stock...
Friday at 8:06 AM
robin-fo
Macintosh Quadra 950 green screen output
This is normal and happens with many Macs. Try different adapter settings.
Friday at 7:14 AM
TheElk
Are you sure we all have the same V6.8 version like you ? Could you test with a white prelude tape ?
Friday at 6:55 AM
T
toples50
Reviving a sad looking Quadra 840av
My Q840av motherboard
Friday at 6:13 AM
I'm still not seeing any exposure errors with 6.8.
Friday at 6:12 AM
It is the film not, the scanner or firmware, that is getting dark, as the scanner exposure is not changing. The exposure is not changing...
Friday at 6:06 AM
Destroyer1976
Macintosh Quadra & Centris
I don't know if anyone has a solution to my problem but here it goes. I have a mac quadra 950 which I'm running on VGA output. I can...
Friday at 5:28 AM
jackmonte1987
Here is a short video where you can quickly see the transition. I power cycled the unit and retried the scan, and it did the same around...
Friday at 5:04 AM
jackmonte1987
so I got everything set up and did my first capture which went well, it was only a minute long. However my second capture also went dark...
Friday at 4:53 AM
Marconelly
Anyone tried installing LC575 speaker in Color Classic?
I will try,, but it’s possible that he didn’t even notice it since the connector does snap in place, just harder than it normally should...
Friday at 3:46 AM
Mac 128k Analog Board 820-0082-B from 1983
Yep! Just ordered the kit. Been so long since I opened it up and it looked like a part number i just assumed. Thanks!
Friday at 3:45 AM
geerlingguy
Reinstall Mac OS on iBook G3 clamshell with only USB port?
I *was* able to boot off the USB drive, but not with the 9.2.2 Universal installer copied to it. So I pulled out a 650 MB CD-R, used...
Friday at 3:40 AM
