TiBook G4 1GHz stopped recognising any ssd/hard disk
It could be possible the flat connector cable has developed an open trace. They are designed for a very limited connect/disconnect...
Oct 11, 2025
Peetz0r
Yes, that is what I think I did by unplugging. Most if not all of the things I tried, I have done multiple times, with and without the...
Oct 11, 2025
Right, so my suggestion is to remove it from the IDE chain to eliminate any master/slave conflict it may be having with your SSD, and...
Oct 11, 2025
R
rms337
Here is an example of mine during capture. B model v6.8 with a 32GB card. It did the same with 4GB card (just trying anything at this...
Oct 11, 2025
Peetz0r
The CF adapter does have a jumper, but I didn't touch it since it worked. I tried swapping it anyway, no difference. The mSATA adapter...
Oct 11, 2025
F
frontein1
@JDW yes lots of really good info regarding overclocking the MEMCjr and djMEMC. That is next on my list to continue that. Otherwise...
Oct 11, 2025
Anyone tried installing LC575 speaker in Color Classic?
Great ot hear! So I guess it is then a decision that boils down to this: Do you want more volume, or do you want stereo? Because it's...
Oct 11, 2025
Can se/30 flyback be replaced by a 157-026C flyback?
If the rod is truly used ONLY for structural support reasons, then it shouldn't affect anything electrically if left broken, I wouldn't...
Oct 11, 2025
Peetz0r
If I boot it without holding any key, the blinking question-mark-folder/finder-icon appears. If I boot while holding option, I get the...
Oct 11, 2025
Does your CF adapter and/or your mSATA adapter have a Master/Slave jumper on it? If you completely disconnect the optical drive from...
Oct 11, 2025
