  • PastaThief
    Well, since you did say that it's never too late for a response, I wanted to chime in and say that I ran into the issue that you were...
  • JDW
    JDW replied to the thread Se/30 c6 cap lead lifted.
    Sorry, but which side is lifted? I had thought the + side was lifted and based my previous post on that assumption. You are speaking...
  • JDW
    JDW replied to the thread LC520 Overclock.
    Thanks, @dougg3 ! So basically we need only remove 3 resistors, not all 4, despite what the book Doping Mac has to say. And Doping Mac...
  • D
    dougg3 replied to the thread LC520 Overclock.
    My assessment is that R80 only matters if you are using a ROM SIMM. It shouldn't matter for any kind of overclocking or conversion from...
  • JDW
    Seems the two pads are shorted together with solder, which needs to be rectified... I can also see the tiny trace to which the pad...
  • JDW
    @dougg3 & @kefkafloyd Your recently posted findings seem to indicate that, regardless of whether R80 is left soldered in or removed, it...
  • D
    Yep, this is definitely the same circuit as the CC. I just beeped it out as best as I could on my 820-0368-A board from a caddy-loading...
  • JDW
    "IDE"? Sorry for my ignorance, but does this mean there will be a BlueIDE or similar drive that will, at long last, allow me to get a...
