S
Scorpio_ny
Quadra 700 video corrupted
That’s good to know! Thank you for sharing!
Oct 17, 2025
P
pff000
After some time the screen had a stronger periodic pattern with black bands, suggesting that it should be the first or last of the 4...
Oct 17, 2025
thecloud
AFP client for post macOS 15.5 macs
You are more optimistic than me. The removal is almost certainly being driven by security concerns over having code in the system which...
Oct 17, 2025
S
Scorpio_ny
How did you determine which one was the bad one?
Oct 17, 2025
N
NJRoadfan
Apple needs to fix longstanding issues with their SMB client before folks finally give up using AFP. Granted, most all of the commercial...
Oct 17, 2025
Figgy2112
PowerMac 8600/250 BEOS Woes
That thought crossed my mind, but I’ve never seen reports of people having audio issues because of a cpu upgrade, this computer also...
Oct 17, 2025
Knezzen
I resurrected an old Hotline client
So, bumping this thread a bit. I'm quite a few releases in I've finally reached feature parity between the three targets (68k, PowerPC...
Oct 17, 2025
maikol
Looking for help with Asante MacCON+ LC - Network Card
Macintosh LC & Performa
Hello everyone, first time poster here. I am looking for help in getting an Asante MacCON+ LC NIC to work with my LC475. I have...
Oct 17, 2025
If you still have a blue shift when you set a +2.0 WB, that would mean I have to increase the range in the firmware. So that would be...
Oct 17, 2025
K
KennyPowers
Found an interesting 128k..
Interesting. The hole pattern doesn't match the placement of the screws that hold the two halves of a MacCharlie together, and even if...
Oct 17, 2025
jackmonte1987
I will try it again when I get home, but I messed with the settings for about 10 or 15 minutes and that was the best I could get.
Oct 17, 2025
You just have the white balance wrong. You have the White Balance at 0, is should be +1.5 or +2.0 for this film. The white balance is...
Oct 17, 2025
