Looking for help with Asante MacCON+ LC - Network Card
Apologies if you already know/did this, but did you check your AppleTalk and TCP/IP Control panels are set to Ethernet and not the...
Oct 18, 2025
PaulOckenden
Ah, thanks.
Oct 18, 2025
maikol
Thank you. In your case, you made the resistor modifications to enable a mode change to 10Base half-duplex?
Oct 18, 2025
jackmonte1987
I believe this is a known issue because the unit can't handle the bit rate of the video. It should play fine on a computer
Oct 18, 2025
PaulOckenden
Quick report on V6.9, type C. Won't play back using the unit, although movies are saved to the card. When I press play on the unit it...
Oct 18, 2025
S
Scorpio_ny
Thank for that info.! I will give you a follow up shortly..... stay tuned
Oct 18, 2025
jmacz
I haven't had luck with those card extensions, at least various ones available on Amazon. A lot of them seem to be slightly off in...
Oct 18, 2025
S
Scorpio_ny
Hi @JDW, I had left you a reply on on another thread about the item you are looking for. I believe this will fit the bill. It is the...
Oct 18, 2025
jmacz
@JDW I need two measurements: 1.) For the additional four holes on the wall-less model, how far forward you want them compared to the...
Oct 18, 2025
LeadedSolder
MK4332x8 32K module for Apple III: trying to figure it out
Apple I/II/III
Hello all, Long time annoyance, first time contributor. As some of you may know, I have an early Apple III (128K; 12V RAM board)...
Oct 18, 2025
TechnikTobi
Color Classic Troubles
Thanks for the additional info! In the meantime I also took out my trusty Tektronix T912 and did some test on the voltages: -...
Oct 18, 2025
V
vtgearhead
Unfortunately, the vendor will not ship Mitutoyo products to the US. We're too busy winning I guess.
Oct 18, 2025
P
pff000
What's the best Video solution for a Vintage Apple IIe in 2025?
One option that has worked well for me is the RGB2HDMI device. In my Apple II plus it can pick up the digital video signal for a...
Oct 18, 2025
