F
frontein1
I'm pretty close to getting 512MB to register in the Q650, at least I hope. I do think it may have to do with the power/voltage drain by...
Oct 19, 2025
Regarding the LED being slightly off-center (to the right), relative to that rectangular window hole on the front plastic case of the SE...
Oct 19, 2025
Knezzen
I resurrected an old Hotline client
Thanks for the kind words! :)
Oct 19, 2025
Calipers were just delivered! Finally! It’s 8:00pm here right now. Note that it uses a low-drain SR44SW silver oxide battery...
Oct 19, 2025
Jockelill
This is were I also got stuck, maximum 328MB RAM :), if you fix it it's incredible :D
Oct 19, 2025
Faster Baud and More Serial Ports (CSI Hurdler, SerialDMA, QuadraLink)
Welp, there's the problem. They are using 256000 baud because there doesn't seem to be a predefined CBR value for 230400 baud. I can't...
Oct 19, 2025
I broke out the oscilloscope to determine if something is wrong with Basilisk II. I believe there is. First, here is a Quadra 840av...
Oct 19, 2025
