Screenshots from my LCD Color Kit Video… But the ribbon cable is short and really made for the 15-pin connector to mount in the...
Oct 19, 2025
S
sheider
I concur with your goal to focus on improving image quality before pursuing "convenience" features. That said, a lot of questions /...
Oct 19, 2025
PaulOckenden
What are the chances of having (fairly rapid) auto-exposure that varies through the capture? Set a level on a good frame then try to...
Oct 19, 2025
PL212
BlueSCSI Toolbox - NeXT Edition
Really appreciate your work on this! I have an 030 cube for testing once you reach that point.
Oct 19, 2025
Faster Baud and More Serial Ports (CSI Hurdler, SerialDMA, QuadraLink)
Ahh. That is much more practical. I did not previously notice the line "This member can be an actual baud rate value"
Oct 19, 2025
F
frontein1
What you said @trag :) I also noticed all of my SIMMs are EDO not FPM. But I am not sure if that makes much of a difference with power...
Oct 19, 2025
7.0. Will have a fix for the issue would scanning over 16384 frames. New ideas of v7.0 are welcome. I want to add support negative...
Oct 19, 2025
T
It may not be power drain per se. It may be that the memory controller does not have/use enough drive strength for the number of...
Oct 19, 2025
lundpk
Hi from Minnesota
Right now, my collection is very small. I have a 512K Classic Mac that is fully recapped and floppy rebuilt. A PowerMac 7600 that I...
Oct 19, 2025
