Faster Baud and More Serial Ports (CSI Hurdler, SerialDMA, QuadraLink)
David, I found your thread an interesting read! What is your practical use-case for all that speed?
Oct 20, 2025
Sony CR44 PSU from Mac SE - Left on with no load over night
Honestly, I've never left my Sony CR44 PSU powered-on in a No-Load condition for more than a few minutes to take measurements. I...
Oct 20, 2025
It is very unlikely that there is a macro lens, with sufficient quality, and doesn't require a different mounting position. I've tried...
Oct 20, 2025
Unfortunately change anything in the UI is likely much more work than quality enhancement. All changes are through educated guesses at...
Oct 20, 2025
BeigeBoxSC
Compact Macs
I stayed up late recapping the PSU because I was on a roll. I tested it and got good voltage. But accidentally left it on overnight...
Oct 20, 2025
It has an AGC, just not as fast as the stock FW. It is has limits to prevent too much gain lift black too much into grey. The speed of...
Oct 20, 2025
The following info from ChatGPT needs to be vetted, but it does make sense... And here are excerpts from the "KM44C16000.pdf"...
Oct 20, 2025
S
sheider
I wish you luck with the 16mm macro lens... IMHO, the ultimate "practical" goal would be to determine a lens / spacing combo that...
Oct 19, 2025
