jmacz
Ok, the new models are published. https://www.printables.com/model/1436037-macintosh-se-scsi-drive-bracket...
Oct 20, 2025
jmacz
Well, I could have been totally unlucky :) possible I got a bad batch or something. But I did see afterwards there were a lot of reviews...
Oct 20, 2025
Yeah, I searched FAR & WIDE for a good bracket that would accommodate the rather huge black plastic extenders that I have now. But...
Oct 20, 2025
Inside, yes. I stayed up too late last night and was losing my mind, sorry. I edited my earlier post to say this instead... So the...
Oct 20, 2025
jmacz
Oh, you found those? :) That was before I gave up on the extensions. I think I had a variant for the Quadra Nubus slot covers also. But...
Oct 20, 2025
jmacz
When you say "rightmost edge", are you looking at that rectangle from inside the case or from in front of the case? It looks like you're...
Oct 20, 2025
jeffburg
iMac G4 constantly crashing/kernel panics
Oh yeah, and the other thing I forgot about is that if you did open the machine, did you reapply thermal paste to where the heat sink...
Oct 20, 2025
jeffburg
its hard to say. Usually freezing like that sounds like a RAM issue. Especially if it's so consistent. When you said you maxed out the...
Oct 20, 2025
I had the following Expansion Slot bracket printed at JLC in the past, but it doesn't fit the SD Extender I have (but admittedly, I've...
Oct 20, 2025
Faster Baud and More Serial Ports (CSI Hurdler, SerialDMA, QuadraLink)
Oh, so it's a "techno-geek experiment" then. I see. I was just curious because when I do geeky things like overclock a motherboard...
Oct 20, 2025
Because.... Why not? 😂
Oct 20, 2025
